What I come across with many of my trackers is that it runs for short while quite okay. But after a short while it will constantly give a false indication of a new change. You can see in the picture that it says that one part has been removed, and the same time the exact same thing has been added.
Unfortunately it doesn’t. When I check it myself the lay out of the page stays completely the same. I have already tried to put a delay in the configuration but that doesn’t seem to help either.
That’s interesting. Distill saw the list in different order when it opened the page in a background pinned tab (assuming that dynamic is set to true). It could mean that the page can load differently when it is loaded in foreground compared to a background tag.
Can you share the URL? I can try it out and see how it works.
Aah alright. It is strange because it can ruin smoothly for 3 hours and then all of a sudden without any reason it just constantly gives the same change.
No worries. Can you please share the URL too that is opened in the screenshot? The earlier URL is different from the one open in the screenshot. Thanks!
