Error Actions v2
Hey Folks,
This week we released the Error Action v2 to configure notifications for erroring out monitors.
It can be accessed from the Options Menu:
and from the Setting Page as well:
It is currently available for the cloud and will be available in the Extension and Desktop App in the coming weeks. Do give it a try and let us know your thoughts!
every time I restart my laptop the local error actions reset, took me a while to find out where the error noise was coming from. It defaults to 5 error actions, when I don’t even have that many alerts set up.
Is there any way to turn it off permanently?
Hey @satyris410,
Thanks for reporting the issue. We’re on it and will update you shortly.
Hi @satyris410, We’ve released a new version of the Desktop App which fixes this issue. Once disabled, the Error Actions won’t be enabled after the restart. Can you please check it once?
You can uncheck the Trigger Notifications checkbox to disable it.
Perfect, thank you for sorting this so quickly!
