I use to have disabled monitor and I enable it manualy every 1 or 2 weeks (due to capcha on monitored page). I set frequency of checking 10 days and when I enable it for run, it runs twice at same day, what is useless.
Is the 10-day interval there so that you need to check them exactly after 10 days or only a way to make sure that they are not checked sooner? If it is latter, one option you can try is keep the monitor off, can check them for changes only when you want to.
It looks strange. I changed interval to “never” and then I ran it manually. It again rans twice.
