Hello,
This has been going on for some time, but every time one of my checks gets a hit I get a double push notification on my iPhone, one right after the other. Is there anything I can do to fix this? iPhone 8 running ios 16.7.7. Sorry if this has already been discussed.
Thanks.
can you check if there are two push notification actions set, one in global action and other one in the monitor’s options?
Yes, that was the problem, thank you very much. I have always set push notifications in the monitor options, but I must have turned on the global option at some point.
Why do i get double push notifications? And does it affect how many checks I use?
