Does each monitor only have ten historical records?
Does each monitor only have ten historical records???????????????????????????????????????????????????????????????????
@guoyijun Yes, the number of saved historical versions depends on where the monitor is stored and which plan you are using.
For monitors in the Extension Watchlist, the saved change history is limited to 10 versions.
For monitors in the Web App at https://monitor.distill.io/, the Free plan includes 3 saved versions. This limit increases when you upgrade to a paid plan. Note that the extension keeps 10 versions even in the free plan.
You can check the details under Version History on the pricing page:
https://distill.io/pricing/
