hey @natlipson, what does the change history show for this monitor?
also see the following post. it mentions the checklist that can be used to find out what could be preventing the alert from triggering. it is usually checks or conditions. let me know what you find out.
yes, this is it. the change history displays the captured values.
also notice a button with a “bell icon” for each version in the change history. clicking the button will open a condition debugger modal. it helps understand why a change didn’t (or did) trigger the notification. check them out and let me know if you have any other questions.
it displays the condition’s evaluation result. additionally, using the option to “test conditions” helps refine the conditions. let me know what you find out. thanks!
I am sorry @ajitk , but I don’t follow, The condition is clear: look for ‘Citizen Card’. This string appeared on the page after I set the alert - and I received no notice of a new post that contains this string. This is what I am trying to understand.
The condition was evaluated as False. So no alert would have been triggered.
The condition is applied based on text extracted from the web page. Since Instagram displays posts as images in the feed, any text embedded in those images cannot be found and used in conditions.
However, you can monitor content such as the number of posts, follower count, or comments on a specific post.
Wow! Thanks @raksha !
Does this mean that if the string appears in the comments, not the original text, of the post - the alert will pick it up?
Also, if I may: if I am looking for “citizen card”, will “Citizen Card” (upper case) and “citizen cards’ (plural) will also be picked up?
No. For monitoring comments in a post, you will need to create a separate monitor for that post.
Conditions are case-insensitive. So, “citizen card” will also match “Citizen Card”. “citizen cards” needs to be added as a separate condition.
Please note that the condition applies only to the text and not to the text within an image. As a result, these conditions won’t work when monitoring the Instagram profile page.
