Hello
I’ve searched the forums and found some useful info (and I’m -seriously impressed- with the level of support!), but I’m still new enough with this that I haven’t solved my problem.
I login to a site that lands on a “Dashboard” page with a banner menu. The menu items don’t display specific URLs, but rather load dynamic content in the window (frame?) below the menu. I would like to monitor a dynamic element in one of these dynamically-built pages.
I’ve attached a screenshot that hopefully shows enough to better illustrate the situation. Once logged in on the “Dashboard” page, I click on the “Cookie Exch” menu item, and it loads the list of items below. Clicking on one of those items (the blue bars labeled “Adventurefuls”, “Lemon-Ups”, etc.) displays what (if anything) is available in that section. In the screenshot, the areas boxed in red are examples of when something is available; the area boxed in green is an example of what would show by default if nothing is available (“No offerings at this time”).
I would like to be able to monitor when one of these sections (like the “toffee_section”) changes/has something available (the section boxed in red in the screenshot).
However because I have to login, then drill-down through the menu, and the content is dynamic, I haven’t been able to determine how to setup the URL (and as a result, the element) to monitor.
Any help is appreciated; I can try to provide more code information if needed.
Thanks very much!
Regards,
Mike
Use the Visual Selector to select elements for monitoring. On the “Options” page that appears after making your selections, change the device to your local browser to ensure the page remains logged in while the Macro performs its actions.
Optionally, you can create a Macro to handle both logging in and performing the actions described in step two. This approach allows you to run the monitor in the cloud as well.
Thank you very much for the quick reply. I signed up for the Starter level to enable Macros, and was able to get the login and the basic display of the “Cookie Exch” item list recorded and displaying properly.
However, the last step, accessing one of the listed items (in this case “Toffee-Tastic”) does not complete. Instead, that last step eventually times out with an error:
Timeout 30000ms exceeded. Error evaluating statement: “click”. at Position: [6]
Is this referring to a problem with the “Click” in the previous (second-to-last) step, (which seems to be step number 6 in the macro)? I’ve tried adjusting the x,y coordinates slightly, but still get the timeout error evaluating the click at Position 6.
Screenshot is attached.
Thanks very much!
Regards,
Mike
Thanks for the update @magicpiegod. The reported error is encountered when the selector could not be found in the page. I was wondering if fixing #toffee_section_wrapper [class*='showhide'] will solve the problem.
Can you share a screenshot or element’s HTML with id toffee_section_wrapper?
Thanks for taking a closer look. Here’s another screenshot of the HTML elements. Hopefully if shows what you need, but if you need anything else, please let me know. And again, as I said in my first message, I’m very impressed with the support you’re providing for your products!
Regards,
Mike
Thanks! The element and the autogenerated selector look alright. Can you replace that selector with the following and see if that makes it work? Click the overflow menu icon for the last click step and click “Edit Step”. [
I just noticed that the page has an iframe and the content at the last step is in an iframe. Can you right-click on the highlighted link in a new tab and use Macros to monitor?
Thank you for the additional idea. I tried using the URL specified in the iframe src, but unfortunately the page just comes up essentially blank (in display and source).
That worked for most of the macro, but at the last step it still throws the same “Timeout 30000ms exceeded. Error evaluating statement: “click”. at Position: [6]” error as before, using both selectors mentioned earlier:
#toffee_section_wrapper [class*=‘showhide’]
and
#toffee_section_hdr [class*=‘showhide’]
in the last step.
I’m sorry I’m not more familiar with how all this works, but thanks for your guidance. Obviously any other suggestions are appreciated. I’ll keep trying things as well.
