Delayed webhooked calls now [fixed!]
Hi!
All webhook calls are delayed about 6 minutes now.
Does it happen for everyone?
I’m running Distill Web Monitor app. Tried restart a few times.
edit: It seems to getting better. About 1 minutes delayed now.
edit: back to normal now
@Edvision Thanks for reporting this — and glad to hear it’s back to normal now.
To help us understand what may have happened, could you let us know:
  • Which webhook endpoint/service you’re using?
  • Are these webhooks triggered from Cloud monitors or Local monitors?
  • Roughly what time (and timezone) you noticed the delay?
Webhook call to my own site ( edvision dot se ).
Local monitors with live monitoring.
From around 07.00PM/19.00 to 20.00 CET(GMT+1)
I have used your service for several years and have never had such long delays.
@Edvision Thanks for sharing the details and the timeframe — that helped narrow it down.
When we checked our backend logs, we could see that webhook attempts during that period were failing with the following error:
Hostname/IP does not match certificate's altnames: Host: www.edvision.se is not in the cert's altnames: DNS:edvision.se
Because the webhook request was failing due to the SSL certificate hostname mismatch, the system retried the request after a delay. The pause between retries is what caused the webhook calls to appear delayed.
Once the endpoint started responding successfully again, the webhook delivery returned to normal timing — which matches what you observed.
You may want to verify that the certificate presented by the endpoint includes the correct hostname.
Thanks for looking into it. I will check my ssl certificate settings.
