Daily checks doubled in statistics
Hello, I have 5 monitors on cloud, each scheduled every 6 hours.
As a consequence, I would expect to have around 20 checks every day
And yet, in the statistics, my Daily usage appears to be double that number.
Anybody else had this problem?
check out the faq on the pricing page:
essentially, the net amounf of checks consumed depends on time taken for each check. if a check takes more time, they will incur more checks on every run.
you should consider using local monitors for checks as you are in a free plan… local checks are unlimited. it is a great choice for most users where using cloud is not an essential requirement.
Thank you very much.
Sadly, I mainly need checks when my pc is off, so local monitors are not for me.
