Create a template, copy or Duplicate a Monitor
Is there any way to copy an existing monitor that i have already set up or create a usable template so that i dont have to manually create each one? A lot of the options are the same for the different monitors i need to set up so it would be quicker to work off a template or copy/duplicate one that i have already set up
sure, you can duplicate a monitor easily using the duplicate option in context menu as shown below.
