Convert existing webpage monitor to RSS feed
Hi
If I have set up a sieve using a the webpage monitor with specific elements on the page selected, is there a way that I can convert it to an RSS feed monitor?
I haven’t found any way to do this from the sieve settings, but was wondering if there is perhaps another way, or a feature you would consider adding.
an existing monitor is of a specific and it is not possible to change the type of an existing monitor. it is best to create a new monitor using the feed as the source.
