Cloud monitor keep forgetting password
Hi, i have followed instructions and put a moinitor on on amazon wesbite. however, after few hours it forgets my password, so i have to go in the profile and reenter the password and save cookies, which is time consuming. how can i fix it?
@moazzam7871 all checks in a cloud happen in a completely new session. this is the default behavior. create and use dedicated cloud device to persist a session across multiple checks. check out the following article for more infomation:
thanks followed the instructions but same issue, after few hours it forgets the password.
it looks like the session times out even. will using a macro to login automatically in case you are logged out work? the macro can work if there is no 2fa or captcha involved.
thanks, yes there no 2fa or captcha. just the password. how can i setup maco in my case?
check out the following articles on how to use macro and using it for logging in:
feel free to reach out if you need any help configuring it.
