And none of the “Google Chrome” selections appear to be working. I am logged in on multiple machines and they have sync on if that matters, maybe the DB file is corrupt? But I have removed and re-added the extension a few times.
this screenshot is from the webapp at monitor.distill.io (notice the suffix “this device” after the device name). is the distill’s extension installed in the current browser? you can access that by clicking its icon in browser toolbar and clicking “go to watchlist”. this will open the extension’s watchlist. it can be used to check monitors locally.
can you try this out and let me know if you face any issues?
I have also encountered this vulnerability many times, the reason may be that the plugin is not loading normally, try to log out, uninstall the plugin, reinstall the plugin, and it should be successful
