Is it possible to check some websites with hard refresh? Without cached files.
Hey @alertmebot, can you try the following extension to clear cache automatically and check if it helps?
Thanks for the answer. I am already using this extension. I was just wondering if this process can be done directly with Distill. I guess it can’t be done. Thanks
