Changing the ‘Maximum number of concurrent workers’ setting does not take effect correctly.
For example, after increasing and decreasing the value several times, it’s currently set to 7, but only two tasks are being checked concurrently. Changing the value to 5 in this state seems to result in zero concurrent checks.
I do not have such a monitoring method. I don’t change the monitoring method from the default.
It looks like Distill was updated recently, since the Watchlist changed. My issue seems to have started around the same time. My Distill is currently version 3.12.6.
