Hello, I am trying to use the cloud monitor feature for the following website and no matter the element selected it comes back with an error. How can this be fixed? It was working fine just a couple of days ago. I tried various proxies with no luck. Sometimes the website gives you a server error if you refresh too often. I tried everything and have not found any resolution.
Hello @mwerb - welcome to the community forum. i think that this site requires cookies in order to access the linked page. Can you try creating and using a profile[1] as shown below:
Thanks Ajitk - I believe I got it working. However, it doesn’t look like I can confirm it is monitoring properly and working? When I attempt to check the log of activity it just says: “Log for this monitor will be available on device that runs this monitor”. Doesn’t seem like I am getting any error though?
I see. Using a macro can potentially be an option. How you normally navigate to that page when starting in a new browser profile or an incognito window?
@ajitk so I tried the macro with going to the main website, clicking yes I am 21 or over, and then navigating to the whiskey release page however it is showing errors and not working.
I am attempting to monitor the specific element on the release page which shows “ Showing 1-9 of 9 results for” so that way I know when they add or remove products.
Is there a way you could do some trial and error to see what ways we can possible come up with a solution to monitor the whiskey release page and know when they add or remove products? Ty!
@ajitk unfortunately the local monitoring is now giving me the same problem. This was all working fine with both local monitoring and on the cloud last week. Not sure what changes but I really need to find a solution! Ty for the help
@ajitk do you have any understanding of how to get cookies to save on a website? So it doesn’t keep resetting itself and blocking me from access on that specific page?
@mwerb using a macro didn’t work in my tests too. Profiles are the way to save cookies that are used for checks by a cloud monitor. It is possible that it needs something else as well that we are not able to send. It requires a deeper investigation. Is it possible for you to reach out to the website and discuss if your account can be allowed to monitor the page?
