I am trying to monitor rental properties. I want to auto apply. I have set everything as seen in the file it just goes and clicks stuff which worked fine before. But just now it started not to load. I have increased my macro actions. No help.
Just a blank white screen: chrome-extension://-some long text–/common/blank.html
To help us investigate the issue, could you please share your monitor configuration and macro configuration files with us? We can load them and take a closer look to understand why the macro is now opening a blank screen.
@e.bilgili Thanks for the update and for sharing what you found.Running macros with local monitors can sometimes have limitations compared to cloud monitors. Glad to hear that switching to a static approach resolved the issue for you.
If you run into something similar again, feel free to reach out to us via support@distill.io and share the monitor and macro configuration files. That allows us to load them in our environment and debug the behavior more effectively, which helps us guide you toward a better solution.
