Awake from Sleep returns many false positives
Using the Chrome extension in Vivaldi, Windows 10 waking up from sleep sometimes, not always, results in several false positives with only a “0” displayed in the details.
I suspect it’s a timing issue with network availability but I don’t know.
None of these had new activity:
@glenn1963 distill gets the monitored values from the page that is opened for chacks. can you check if the page shows “0” when waking from sleep? if the page takes slightly more time to load its content, you can try increase the delay (wait for duration) settings in the monitor’s source options.
Hey, thanks Ajit, I will play around with that. I see there’s also some Global Conditions that I will try, like minimum text length.
I appreciate the reply :slight_smile:
