Automatically clear cookes and local data for a site when it gets the error state
Komplett.no/se/dk will eventuelly error out when scraped, and the only way to resolve it is to clear the cookes abnd local data.
Would be nice with a option to clear out all site information on repeated errors in the separate application.
And a option to open up sites it detects changes on in your local browser, not the built in one where you may not be logged in.
how frequently do you run into the error needing you to clear the site’s data?
this should be possible for distill to do for the desktop app where distill has full control over it’s browser’s cache. will it also work for you if all checks happened in a new session every time?
check out "Open Page In Tab" in a specific browser? - #6 by airfare. feel free to chime in that thread.
That might solve one of my problems too. I have a check that opens a product page. For some reason sometimes it starts redirecting to a product list, but if I open that same URL in my own browser it shows the page for the specific product as it should. But opening it in the Distill browser redirects me to a product list.
Not sure if it’s a cache problem, but might be. Opening a new session every time might fix it.
Maybe this could be an option on specific checks which are misbehaving.
i will see if we can support checks in an “incognito/private window” when using the desktop app.
Hello @airfare,
Thank you for reporting your issue here. I’m pleased to inform that the latest desktop app supports incognito monitors. If the monitor is configured to run in the Desktop app, you can now tick the incognito option in the monitor’s options page (by opening the config) to run the monitor in an incognito window every time. It will be like running the monitor in a new session every time.
