Audio notification stopped working
I am using the desktop app on Windows 11 (x64 3.9.4 beta) and it worked fine - until yesterday. I did not change anything significant (I think) but my running monitor will not ring the bell anymore.
It detects the condition though. I checked this with adding “Open page in tab” and it does that. But no audio.
Of course I have checked that my speaker is on (c’mon!). And used the play button in the settings (clear loud sound when testing).
Thanks for any advice!
@timstonne is there any condition preventing the alerts? Check the following article out https://distill.io/docs/web-monitor/using-conditions-to-get-alert-on-important-changes/#how-to-find-out-which-condition-triggered-the-alert
Thank you for the advice. No, as I said: other alert works (open browser page). So it can’t be a condition preventing.
btw: I now tried the e-mail, but I do not get that either. Don’t know if that is the same problem, but the audio notifcation worked fine - until two days ago
Not sure @timstonne. Any ideas @jayakrishnan?
update: works again.
I removed the desktop app from my system and re-started the .exe
It would have my monitor still in there and say there is an update that would be deployed when restarted.
I did so and now, what can I say, the bell rings again!
Don’t know why but am satisified :slight_smile:
