Any way to return an RSS feed?
Is there a way to have Distill return the recent page changes as a JSON or RSS feed?
Would be useful for pulling into Outlook or other app/automation uses.
Thanks! :smiley:
@jamestay thanks for sharing your feedback. rss feeds are not available. but webhooks can be used as a way to push data to external applications. check the docs out at Webhook - Integrate with external apps – Distill. in what way do you need to consume/process the changes?
Thanks I can work with that, might require runnning more scripts than I wanted (the webhook) but a good solution.
