Time Zone Issue
Problem with the timezone used in crontab. My computer is using ET time , I am in ET and all crontab using a EU time - it does not look I can change it. Any idea how to fix? Very surprised I cant change it
@johnstaa Thanks so much for reaching out.
Just to share a bit of background:
  • The Watchlist UI shows times based on your browser’s local timezone.
  • While our servers run in EST, your schedules should still trigger based on the timezone of your device/browser at the time of setup.
So for example, if your computer is set to Eastern Time, and you scheduled a monitor to run at 8:00 AM, it should trigger at 8:00 AM ET.
We’ve checked on our side and things seem to be running normally. That said, we definitely want to help figure this out with you. When you get a chance, could you please share:
  • A screenshot of the cron schedule you’ve set
  • Your system’s current timezone setting
  • And just a bit more on what made it seem like the monitors were using a different (EU) timezone?
That’ll really help us pinpoint what’s going on.
