I used distill a long time ago and i know that we can add some song but i don’t find the place to do.
Can you help me please ?
Thank you.
Hello @MazOr, welcome to the community forum. The ability to use custom audio files for notifications is available under browser extensions. Click the Distill’s icon in browser toolbar to go to the extension’s Watchlist. Then click the cog icon in bottom left corner to go to the extension’s settings. There you are add your own audio file.
You can also check out the custom alerts section at Get audio alerts on website changes | Distill.io.
