Does the usa visa appointment work for the k1 visa
Hello, we are thinking of using distill to get a k1 visa appointment from the US embassy in Turkey. Can Distill be used for a k1 visa? I’ve read blog posts, it usually talks about tourist visas. Does the type of visa matter?
@burcinca If the navigation flow of the page is similar to that of the tourist visas (i.e., the sequence of clicks required to reach the final page that needs to be monitored), you can use the Macro and monitor provided at Distill.io’s blog.
If the navigation flow is different, you will need to record a new macro that captures the specific sequence of actions required to reach the calendar availability view on the visa page.
If you encounter any issues, feel free to DM or email us for support. We are here to help you with the macro.
