I’d like to be notified, if an item on a dropdown-field is added? Is this tracked by default?
Thanks
Christian
Thanks
Christian
Hi @christian, is that a dropdown built using select
tag in HTML? If yes, it should be possible out of the box. If it is a custom dropdown where the list is rendered (added to HTML) only after it is clicked, a macro will be needed to open the dropdown (so that it can be monitored).
