I was wondering if there’s a way to have 1 monitor - but 2 Slack notification webhooks with separate/different conditions.
This isn’t possible because all actions are gated by the same set of conditions.
So it’s kind of a feature request, to maximize the number of cloud checks?
At the moment I have to create 2 monitors for the same item, with just different conditions. It would be awesome to just have one - then depending on the set conditions under the monitor, the action will be executed.
Thanks for the feedback. I could make sense in certain cases. In you case, are these two webhooks 2 going to two different groups of people or just being segmented into two different channels?
